Hello, i have problem with my gs500. listen it on my page http://jerzy.wz.cz/motor.wav
Can you tell me where is my problem? Please, dont speak german, i dont understand and my english is also VERY easy, sorry. |
schwer zu sagen bei der Aufnahme...für Pleuellager wär`s mir zu viel rasseln...vielleicht die Steuerkette?
No idea - i understand, thanks for now
be patient
Saugwurmmensch > I will
Steuerkette, i dont know translation in english, bud i know what you speak about. People on czech bikes forum says it too. is steuerkette endless chain or not? (i think when it leaves factory in GS) |
i'm goose. I don't speak a word english. I want better sound gut so ?
I cant give you better sound, only from my nokia 6230, sorry. but what is important in that sound is clacking in cca 1 second interval.
steuerkette = timing chain or cam chain |
another, longer soundfile where You rev up the engine would be a further help.
When i rev up engine, everything is ok. i can hear it only on neutral(idle running) or when rev down(turn off gas).
I'd say the camshaft axial clearance is too wide.
Lay the bike from left to right. Does the sound change? |
#12 | |
I forgot something, when i start engine, sound is clear, my problem appears only with warm engine. |
you could check, or just replace (it's not that expensive) the cam chain tensioner... a friend of mine blew his out once, and it had about the same symptoms as you are having (rattling in low rpm, running fine at higher rpm)
"....may the grip be with you!..." |
#14 | |
If the clacking disappears when laying the bike on the left or on the right side (with the feet on the ground |
Yes, as said before:
Sounds occuring only in warm engine conditions is - let´s not say good, but - better sign. Quit possible due to wrong adjustments made. A rather loud, metall sound repeating up to 3 times per second is axial clearance of the camshafts. They bounce from sides to sides making that noise. If you hear high frequent "click" sounds, the cam chain (stearing chain) which drives the camshaft might not be configured the right way. And the valve open/close not exactly the way they are supposed to do. There´s the possibility, the chain longened due to wear, or the camchain tensioner might have a scratch (change!). You might want to go to a dealer and get that check, since broken camchain tensioners can lead to fatal engine failure. ...Or the clearance for valve adjustment are WAY out of tolerance, this is eligible for home-checking. Check the video below! Check out these topics: http://www.gs-500.de/viewtopic.php?t=5999 Strange Sounds Explanation, in German language, though. http://video.google.de/videoplay?doc...lve+adjustment Valve adjustment video, in english Translator: http://www.tranexp.com:2000/Translat...esk-german.htm EDIT: Some members of quite bigger experience than me wish to have a soundfile, that covers the whole bandwidth of rpm, including reving up the engine and so on. |
#16 | |
I also checked valve clearance - ok cam chain - ok Can i be satisfied biker |
#17 | |
as in the other tread described: it's possible to get some spacer-plates from suzuki to minimize the gap/play at the camshaft.
Im so HAPPY boys! http://www.nactileti.net/grafika/3ds...smajlik199.gif
I'd like thank everybody who helped me, especially gruenkai for good idea and Eleven7 for good video link! Thank you boys! |
| Zu -> "Engine covers and front fender" | blub1254 | Verkleidungen, Anbauteile und Zubehör | 14 | 17.02.2008 17:09:37 |
| engine covers and front fender | hein vie the | Verkleidungen, Anbauteile und Zubehör | 10 | 27.01.2008 13:21:48 |
| under engine auspuffanlage! | chrimsor | Auspuff | 3 | 15.09.2006 18:04:42 |
| Sound..... | Allgemeines | 51 | 19.08.2006 15:04:17 | |
| Sound | Auspuff | 7 | 27.10.2002 15:39:10 | |
